Minitor 4 doesn't receive
justinbegley_
Windsor, Ontario
Hi guys, this issue has been ongoing now for about 2 weeks.
I have a minitor 4 which has been working perfectly for 5 months, but all of a sudden it won't receive anything. This happened after I started fiddling around with the knobs on the top. I programmed it myself for the local fire dept. Anyways. When I turn it on, it does the normal 8 beeps, but won't recieve anything during the time tests or calls. I have a scanner that I've been listening to, to ensure a call has been toned.
buddrousa
NW Tenn
The A B C D selector is a thin plastic fork and breaks easy while moving the 4 position switch. Can you put it in PROGRAM MODE?
buddrousa
NW Tenn
Sounds like the pager is stuck in C
If this is a VHF program it as monitor and see if it receives
buddrousa
NW Tenn
Then the knob is not in C.
As cheap as a IV is on ebay that is your best bet as parts are hard to find.
