Minitor 5 Question
KD2DXF
Nobody
Anytown, USA
I was given a box of radios, and included was a Minitor Pager. it has "UU" stamped next to the barcode, would this signify that it is a UHF model? theres no other markings other than 136WHE8579. which may be a serial number. Thanks in advance!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Slide the latch away from the clip and then the battery will slide out. There should be a label with the model number and frequency spread.
KD2DXF
Nobody
Anytown, USA
Thank you Steve!! it is a UHF 460 model. Unfortunately I wont be able to use it as were VHF Here.
