Minitor 6 programming
Joefran86
I'm having trouble programming the call tones to a specific switch channel. For example if I want function switch A to go off for call 1 and call 2 tones how do I assign the call1 and 2 tones to it. Thanks for the help.
njffemt08
Was emtfirebug14
are they on the same frequency or 2 different frequencies
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Study this document. It should answer most any question you have about programming the Minitor VI: https://www.dropbox.com/s/fqcs0aipvij41pl/Minitor VI Programming.pdf?dl=0
In short, program up the frequency as you want it on the Channel Fx tab, and then switch to the Function Switch tab and assign that frequency to SW-A using the dropdowns and then pick whatever other options you want for that position. Each frequency has spaces for 10 tone pairs and 5 long tone group calls.
njffemt08
Was emtfirebug14
ok i am attempting to program radio now. last question i have for now is tone a freq/tone b freq is that 1 set for my tones cause each tone we have has 2 numbers per tone
njffemt08
Was emtfirebug14
also forgot to mention how do i know what to put for the code
SteveC0625
What radio are you talking about? This is a Minitor IV thread. Do you mean the PM400 in your other thread?
