Minitor III
mattnelson26
Hopkins, Minnesota
i have a minitor III the just reprogrammed it and forgot to add a tone. but now i cant get it to connet. i think something broke but i dont know? does anyone know where i can get it repaired in minnesota?
thanks,
matt
randyK
Central NC
Are you holding down the squelch button with the channel selector on C & turning it on, to put it in program mode? Just a thought.
TJ_in_IL
I had a similar issue when I went to reprogram a batch of 3's and 4's. I could read, then could not write. I found that if I jiggled the pager in the programmer, it would then work (dirty contacts). Also, are you using the windows version of software? You may have to go in and adjust your com port settings and slow down the baud rate to 1200- not in the software, but in hardware settings. I had to do this for my Minitor V software as well.
