To anyone looking to acquire commercial radio programming software:
Hello, I got a minitor 5 the other day and when I'm charging it, it makes a really high pitched squealing noise. I believe it's coming from the charger itself. Is this normal? Or is there something wrong?
Motorola had a recall on these charges a few years back. Also, it depends on the revision codeplug that is in you're pager. The latest codeplugs and chargers are unaffected by some of these issues. I would contact your radio vendor; depending on how long you've had it, they should be able to either swap it out or have your pager sent into the depot for a codeplug revision...
Correct, they will mostly likely not, especially since the recall was back in 2008. What I'd suggest, if your pager is still under warranty, is to send it in, along with the charger and explain the issue. They will at a minimum, update the pagers code plug to the latest revision and quite possibly swap out the charger since they will be able to duplicate the issue. When you explain the situation, be VERY specific...
You can simple call Motorola Pager Repair Depot; if it's not under warranty, I believe their flat rate repair fee is $78. It's the only place I'd consider for pager repair of the Minitor V's.
Wouldn't it be easier to just buy a new charger for less than that $78? And I have a programming dock, would i be able to update it with that and the software?
Buy a new battery for $14 and charger for $34 and be done with it.Problem will go away. Mine and 45 others did. The whine was charger trying to fast charge the battery so quickly it emits a noise.
If the charger is the bigger Amplified base and the part number ends is A or B get rid of it.Only the C versions work correctly. Wall plugs for them are ok though.
