Attempting to wire a bell to a minitor V amplifier base using the DIN connector on the rear. I have the relay and timed relay all working properly using an external trigger voltage but when I try to use the wires from the plug on the rear, I get nothing. Volt metered the outputs (during an active alert) and it doesn’t look like I’m getting any power out of those wires at all (at first I thought maybe not enough to trip the relay). I tried multiple bases and multiple pages and none will give any power out the dry relay contact wires. Any insight would be very helpful!
