FireDawgEMT22
- Joined
- Jun 15, 2006
- Messages
- 136
I would like to take an old minitor V that doesnt work right (alerts but doesnt open up and it is a hardware issue because the programming is right) and hook it up to a station alerting system I would like to build. I want to take the output signal to trip a relay to sound a bell and trip a second relay that will latch itself and turn on some lights. That part of it is going to be easy with some 24V DPST relays rated at a high enough amperage for the lights. I know I can buy a minitor V amplified charger that has this output in it, but I want to do it for as cheap as possible. So just modifying a standard charging base by adding a pin for it would be best.
According to this website https://sites.google.com/site/radioetcetera/home/firestationalerting . The pin that is used for TX to programmer will output a ~2.5VDC signal (relative to pager gnd) when the pager is alerting. The problem is I have checked the voltage on this pin while a pager is activating and got no voltage. Does anyone have any further information about this?
