minitor V help
kwackstacker
carroll county
Recently all volunteers in my department received new minitor 5's to replace our 3's. The pager has worked nearly flawlessly for the first 6 months with perfectly clear transmissions and great reception. Around Christmas it suddenly started sounding and acting like crap! While on open line it misses tons of radio traffic and cuts in and out of the traffic i do hear. It does however alert to all tones for my station even though it may not be transmitting through the speaker just prior to dispatching while on open line. I have to hold down the squelch button to hear important traffic without interruption. Is there anything I can do on my own to solve this problem? or will i have to send it in for inspection?
Also, my department is in the process of switching over to an 800 mhz system which will be simulcast on the old VHF. could this be part of the problem? thanks!
whitesox4life
Grant Co, IN
Wirelessly posted (LGE-VX9100/1.0 UP.Browser/6.2.3.2 (GUI) MMP/2.0)
does your county have a repeater at every station for the vhf frequency? If so, there could very well be an issue with the repeater and not with the pager. I would go to another station/dept on the opposite side of county and see if the problem still exists. The county also could have changed something at the dispatch center that is causing this issue.
DPapay
Morris County, N.J.
If the problem seems to exist with your pager only, then the pager most likely requires a trip to the depot for a poor rx problem. Check with your buddies to see if they are having any problems as well.
