Minitor v help
nick223
Ottawa Illinois
I have a minitor v the pager turns on and vibrates and the lights blink on top of the pager. But the pager has no voice. The memo voice is turned on for that part but no call voice comes though. Any ideas?
WB0VHB
Mt. Union, Iowa
No static when you press the reset button on the corner either? Was an earphone ever used with this pager? If the answer is no to either question, sounds like a defective speaker.
I have seen several Minitor Vs that had enough metal filings stuck to the front of the speaker grill to greatly reduce audio output. The users of these pagers worked in areas where metal was being ground or sanded.
nick223
Ottawa Illinois
No reset static. Not sure on a earphone what would happen if the earphone was used? I did swap speakers and still nothing but I didn't change the spring and pins that go into the speaker. Didn't think that mattered or does it ?
WB0VHB
Mt. Union, Iowa
Plugging in the earphone jack disconnects the speaker. When the jack was on the top of the pagers, dirt and water would contaminate the connections inside the jack. But now with the jack on the bottom of the pager, this should be as much of a problem.
Do you have audio if you plug in an earphone jack? If no, sounds like a trip south of the border (pager repair depot) is needed. Is the pager under warranty? If it is, opening the case might have made the warranty void.
beachbum92
I to am having this same issue, exact same actaully. although I have noticed that if you hold it up to your ear that you can barely hear it... I to have replaced the speaker.
WB0VHB
Mt. Union, Iowa
Has your Minitor V been used in an area where it could have attracted metal particles to the speaker magnet? If so, you might be able to use compressed air and blow across the speaker grill.
beachbum92
Well I have already put in a new speaker from another pager but ill try that wen I get hone and let you know.
