Minitor V pagers
dixie729
Daviess Co., KY
Had some pagers narrowbanded. When the tones drop, its fine. When dispatch talks all you can hear is an ugly loud squeel when the volume is turned up. Some of them do it and some don't. Anybody know what could cause the loud noise?
Kevin Absher - HTC Inspire 4G
W2GLD
Michigan
Your dispatch transmitter hasn't been narrowbanded yet, we had that same problem here until the county actually changed to narrowband modulation. Test it yourself with a portable radio programmed for both wide & narrow, you'll see the difference first hand.
12dbsinad
Microphonics within the pager itself. Common problem when switching them to narrow. Send them in for repair.
dixie729
Daviess Co., KY
Why would some do it and some not do it. How much does mother M charge for the the repair.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Last pager I sent in was $78 flat rate. We have a MOL account so I can't tell you if that is the rate they'd charge someone who doesn't have an account.
Call Customer Service. They'll tell you. 800-814-0601
dixie729
Daviess Co., KY
I've read in other posts that there is a foam pad between the housing and speaker that needs replaced and that's the only fix. Is that true?
SteveC0625
Mind telling us where you read that? I don't recall any mention of that here in the Motorola forum or over on the batboard? I've never heard this, and find it difficult to believe.
RBMTS
I agree with W2GLD. Try putting the affected pagers back into wideband mode and see if that solves the problem. If the pagers still alert properly and the squealing stops, then you're golden.
SteveC0625
Saratoga County, New York had this exact problem. They run a VHF conventional narrowband simulcast alerting system using 5 transmitter sites. A number of Fire and EMS agencies throughout the county experienced this identical problem with a great number of their Minitor V's.
They returned the pagers to wideband and the problem went away. I've never heard if they determined a cause for the problem, but given the simple fix, it probably doesn't matter.
dixie729
Daviess Co., KY
I don't recall the website. There wasn't a great deal of info on it. I didn't know if anyone else had head anything about it. I'll try and switch one back to wide and see what happens. Do the pagers have to be narrowbanded on vhf band 137-174?
krokus
Southeastern Michigan
We have been having audio quality issues, since going over to fives.
About half of our pagers are new, and they all have this issue.
jim202
New Orleans region
Don't you just love the quality of the Motorola Minitor pagers? You can't spend more money for radio equipment any place else in the world and get ignored on the problems that crop up.
Get in the face of your Motorola sales rep politely explaining what a piece of crap they have sold you with the Minitor V pagers. Boot his car for illegal parking, running stop lights, speeding and the parking too far form the curb. Tow the car for parking illegally. Maybe they will get the hint that their sloppy customer care will not be tolerated.
Putting the pagers back in wideband is not fixing the problem. It sort of hides the problem and makes the audio output low. Plus your never going to be sure the pager will alert.
Be aware that real low tones or real high pager alerting tones will not work well on narrow band. Check with your radio shop to see if you fall into this problem.
