minitor v question
scannersnstuff
when you program a minitor v to stay open for 30 secend's after a tone out,can it be made to stay silent for those 30 second's before resetting ?. i had my dealer program it for me that way.today. i did not realize it would be in the un-squelched position.
wspicer
LaGrange KY
yes you can its called push to listen and you have to use it in vibrate mode what it will do is vibrate, and record the message but will not open, you can then get away outside or whereever you can listen and hit your repeat on the pager
gewecke
Banned
Illinois
This is a handy feature to have. I recently went to a theater to see a flik and mine alerted in vibe mode giving me enough time to listen to the page in the lobby.
N9ZAS
K5RYA
Spring, TX
Push to listen and and vibrate are commonly used together, but if you do not have the stored voice function i would suggest against it as you may miss mission critical information (not sure, but that could possibly affect your compliance with NFPA as well in regards to mission critical communication)
scannersnstuff
because of my requirment's, i had my minitor v set up differently. my channel selector knobs's. control.
a-tone out in closed mode.
b-monitor tone out fq.in open mode.
c-monitor ch#2 in open mode.
d-address off duty. allowing only my primary interest tone set to activate.
because of the somewhat limited configuration plan,i could go with neither scan or vibrate.
GTR8000
NY/NJ Database Guy
BEE00
I assume you're talking about an SV model? It helps to be specific when asking questions so we know what we're dealing with.
In any case, the open squelch after alerting is by design, otherwise the pager would stop recording the message after the carrier drops. In some systems, this isn't an issue because the carrier doesn't drop between the tones and the voice message. However, that's not the case with many systems, where there is a drop in carrier after the tones. If the pager is not programmed correctly, the voice message won't be recorded.
I once again have to assume since you weren't specific, that when you say you had it programmed to "stay open for 30 seconds", that the pager is programmed for Timeout 30 seconds? If that's the case, then the pager will only record 30 seconds of the message before resetting when in selective call mode, or reverting to carrier squelch when in monitor mode.
A better way to go would be Revert N set for 10 seconds. That way the entire voice message gets recorded, even if it goes beyond 30 seconds, and the pager will not reset if there's a drop in carrier between the tones and voice message. The pager will remain in carrier squelch (monitor) mode after the alert until you reset it. You could also go with Delayed N set for 10 seconds if you want the pager to reset to selective call (quiet) mode after it finishes recording (auto-reset).
DPapay
Morris County, N.J.
Yeah, we have been wrestling with that SV problem for many many years now. Once again the /\/\ engineers drop the ball.
