Minitor V Reverts to Monotor Monde on F2, but Not F1
crowleyd102
St. Louis
My Minitor V with Stored Voice Option reverts to Monitor Mode after receiving a page on F2 but not F1.
My codeplug printout is attached.
  • Minitor V Codeplug Printout.pdf
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Your SV Function seems way too short. Run it at DYNAMIC and see how it performs.
Same for the Reset Function. We've found that it needs to be at the very least 9 seconds. I run my Minitor VI's at about 15 seconds, but they have a silent revert mode that isn't annoying. My Minitor V's are all set at 10.56 seconds which is about as much open squelch as any of us can tolerate.
One final point, unrelated to your concerns. I want to thank you for posting your codeplug data on your first post. It makes it so much easier to try to help someone if adequate info is provided from the start.
crowleyd102
St. Louis
Some points about my scenario:
1) F1 has no alert tones active other than the four I programed
2) F2 has lots of active alert tones active, other than the one pair I programed, which alerts very rarely, once a day, if that often
3) If F2 alerts to the tone pair I have programmed, the pager stays in monitor mode, with squelch closed, long after I've heard and recorded the voice message associated with the programed tones for F2.
Should I press the reset button after receiving a programmed F2 page, to avoid listening to all other tone pairs and voice message for other station houses and equipment on the F2 frequency?
I'm a new Minitor user and may not be using it correctly.
Thanks again
