Minitor V voiceless had last thread wrong
nick223
Ottawa Illinois
I had the last thread wrong
The pager alerts but no voice comes though
But if you hold down the rest button it sends the voice though
SteveC0625
Northville, NY (Fulton County)
Nick sent me his code plug and I think I have solved the problem. The Reset Function was set to Revert N with only a couple of seconds until reset. I suggested he move the reset time out to at least 7 seconds or longer.
We'll see what he has to report back.
mojo3120
Revert N has to do with Stored Voice. N is how long after tones go out it holds the squelch open waiting on dispatcher (or anyone technically) to key up radio. ie. if Revert N=7 ..... tones go out, dispatcher waits 8 seconds to start dispatching, the call wont be recorded, just 7 seconds of open squelch.
That doesn't "reset" the pager though. It "reverts" to monitor mode. It should stay in open monitor until the reset button is pressed.
nick223
Ottawa Illinois
Thanks mojo. I had it on 7 yesterday and I wasn't home when we dropped a call so when I got home I played back the message and I got almost the entire tone no dispatch voice. Steve said to place it on 10 but I went higher like 15 I can always go backwards once I get the entire page. I don't get this because all the other pagers are set to a lot lower and they work just fine.
nick223
Ottawa Illinois
Not sure what is going on here i put it up to 15 seconds revert N now it seems like i get the tone and voice but the channel doesnt stay open to monitor and other radio traffic ( red light is on ) also it seems to not record any other calls once there was already a call and red light being on ( seems like you have to rest the pager or turn it off and on. this Pager is confusing me completely
NCFire11
Since this has no stored voice, just use Revert ("automatically reverts to selective call after some time has passed, 10 minutes or so) or Manual(reverts whenever you press the reset button.
mojo3120
again.....Revert does not = Reset. Revert means "revert" to Carrier Squelch. It's really confusing I know, and Motorola could have at least spent more than 30 seconds documenting it.
In plain English
Revert means open monitor until the reset button is pushed.
Revert N is the same thing, but holds squelch open for N seconds (to record).
mojo3120
This does have stored voice though
Revert N=15 should be fine, that's usually what I use for SV unless it's one of those counties that sends out 4 or 5 tones per dispatch. Send me your codeplug & I'll see what's going on
My email addrress is my username @gmail.com
mojo3120
Got the codeplugs you sent. A/B/C on Silent Scan, that's more than likely why you're missing pages. On Silent scan, if someone's yapping on Ch.2 while your tones are going out on CH.1 it's not going to alert.
I see there's tones for both Ch.1 and Ch.1. Are you really being paged on 2 different frequencies?
