Minitor VI Squelch adjustment?
mikey224
Anybody have any knowledge of the Squelch Adjustment in the Minitor VI CPS? Will tightening or loosening the setting affect the amount of tail that is heard after the transmission? Mine is set at default in the middle and has a terrible annoying tail after the transmission drops....
K2NEC
I'm not sure what the software is like for the Minitor 6 but on my 5 I have the squelch level set to 3 and it seems to work well. No annoying tail for me
KDD904
Northern NJ
you may be experiencing the "duration" tail for a unit with stored voice. If the SV setting is set to a specific duration, you will likely hear squelch up to that duration if the message is shorter. Best to set to "dynamic" so that it shuts up after the transmission.
mikey224
I haven't changed the Squelch setting yet and experimented, But Its the same amount of tail on a Monitor only channel so I don't think it has to do with the Record or Reset settings, Its a typical squelch tail after the transmission, it just seems a little long and pronounced. It could be normal but i wont know until i change it and see, was just wondering if anybody else notice it as well...
