MIPS 5000 compatability
Harry2318
does anyone know if a MIPS 5000 console will work with Harris/MACOMM radios? I know the MIPS gateways can be modified to allow voice TX/RX but can it be modified to allow emergency functions such as man down, PTT ID. etc.
hlappel
Mip Interface
is the harris radio in analog or P25??
currently mip supports
local control
tone control
digital (Motorola SB9600 with Apex 7500)
Mototrbo
if its analog supporting MDC you should be ok but if its P25 then you will need the Apex and digital gate
N1GTL
CT
local control
tone control
Mototrbo
I just ran into this issue and this is correct!. If your using P25 and the digital gateway, the APX Consolette will not give you PTT ID on your display. You have to use an APX7500 mobile radio.
