According to the instructions for this amplifier when you shut it off it is a direct through how much power is it safe to run through the amplifier with it off I've only been running 5 or 10 watts through it was wondering if it's safe to run 50? Also with the amplifier off I'm able to transmit with 440 on Five Watts and checked the SWR and it is fine but there's quite a bit more loss then on two meters is this safe to do? I thought it would be safe to run because the SWR reading was good going from the radio to the amplifier off any thoughts appreciated thank you
Sent from my SM-N920T using Tapatalk
