Mirage B310 VHF amplifier issues
N2BRI
Amplifier normally puts out 110 Watts today fuse blew 20 amp replaced fuse amplifier is putting out 125-plus Watts according to my meter and is making my RS 20 which is normally 13.76 volts jump to 16 volts during transmission when I used my 220 radio at 60 watts on the same power supply power stayed at 13. 7 is the amplifier going bad
Sent from my SM-N920T using Tapatalk
ramal121
Lots and lots of watts
Calif Whine Country
DMM may be picking up stray RF and giving false reading try dummy load on amp happens to me all the time also 20A fuse a little light for your amp.
AK9R
Staff member
Super Moderator
Central Indiana
The Mirage B310 is a 2m amplifier designed to be used on 144-148 MHz. It is not designed to be used on 222 MHz.
The Astron RS20 power supply is rated for 20 amps intermittent service and 16 amps continuous service. The Mirage B310 is rated to draw 15 amps "typical". That's right on the edge of what your power supply can provide. I'd consider getting a larger power supply if you plan to use the Mirage continuously.
