i
I can't say I have ever heard anything on them. I used to run unitrunker semi regularly just to log talkgroup hits. That was from around when the combined dispatch center opened, maybe early 2018, to sometime in 2020. In however long I ran it for logging in that time, TG12572, which is labeled as being SBFD Dispatch, had 13 hits. In the same unknown number of hours of logging this site, TG12571, which is the County Fire Dispatch/Locution had 827 hits. The TGs labeled as SBFD Fireground had similarly low numbers of hits. At some point I removed them from my G4. I'll have to dig out my SDR to see if anything else is being done on those TGs now. Early on after Mishawaka, St Joe County, and SB all moved to the combined dispatch center, two of the TGs that were originally marked as SBFD Fireground were changed to Mishawaka PD Dispatch and Ch 2 so I also took that as a sign that South Bend Fire wasn't using them. I do see that someone has a few of those talkgroups set up on Broadcastify Calls. If anyone has access to looking back at old calls for those talkgroups they could see if there is any recent use.
