Missing a lot of calls on my P25RX
KSPILOT536
Park City,KS
I updated my software to 2021/11/6 and I am missing many calls,I have a scanner app on my phone and comparing I will get 10 calls on the app and maybe get 2 on my P25RX in the same timeframe,I went back to my previous version of 2021/08/31 and its the same,the P25RX was
FreqNout
Chicagoland
I have not noticed any drop off in performance here between the same two releases. Perhaps something has changed on the system you are monitoring or in your antenna or your config settings. Hard to help you troubleshoot without more info on when it worked best for you.
Motoballa
911 Dispatcher
North Texas
Check your settings and ensure nothing has changed regarding the system you're monitoring, I've noticed on scanner apps some feeds monitor more talkgroups than they list hence why you may think you're missing traffic.
If you have a friend that has a scanner that can listen to the same talkgroups you're scanning that'll be a little bit more reliable than the scanner feeds online.
maus92
OCMD
The parameters of each individual's monitoring site is unique, thus any change in firmware has the potential to affect receiver performance at that site. It is more likely that the firmware change is affecting receive performance vs. a system change.
KSPILOT536
Park City,KS
I think I found the problem,the pin on the end of the short mag mount that screws into the P25RX was so lose it just pulled out of the coupling,I went and recrimped it and it seems to work a lot better now.
