ekmeyer
We have two identical Pro 197 receivers, each using identical Win500 software and configuration files to record the same transmissions on two separate Windows 10 Pro 64-bit computers.
Each will create a recording of the same length for the same series of transmissions -- dispatch, response, dispatch, response, But on one or the other of them, some of the transmissions within the exchange (one of the dispatches or one of the responses) will record as silence (just a low clicking or quiet whooshing sound).
Examples attached. Files a1,wav and a2.wav are transmissions as saved by one scanner on one computer; b1.wav and b2.wav are the same transmissions as saved by the other scanner on the other computer. This situation can happen with either scanner/computer combination. One thing we have been unable to determine is whether this is a recording problem or is matched when listening live.
We'd greatly appreciate any ideas about what we might try to reduce this problem, which seems to have come up only recently, after nearly many years of monitoring the same P25 talk groups.
