Spin it how ya like there analog system blows chunks
No spin here. I'm just calling it as I see it.
The thread was originally about the reason why Mississauga CACC is dispatching out of Hamilton CACC. You responded that it was because the system blows chunks. How you came to that conclusion is beyond me. Are you suggesting that Mississauga CACC moved to Hamilton CACC because the system has low audio and intermod? How can moving facilities solve that problem?
You complain about the system blowing chunks because your scanner suffers from intermod due to a crappy front end. That's not a problem with the system. That's you blaming the system because you don't understand where the real problem lies.
You complain about low audio levels as compared to other systems. Did you ever stop to think that the MOH doesn't listen to other systems? They've probably got the audio levels in the mobile radios cranked to make up for the low audio. Their radios are optimized for their system. Your scanner just picks an audio level that works for most systems but some systems will be too loud and some systems will be too quiet. It's a compromise that doesn't always work.
Have you tweaked your agc levels at all or did you just leave them at the defaults? Have you set up Fleetnet as NFM?
Sometimes you need to get in there and tweak a bit to make things sound better. However, you really can't blame the system for your scanner's shortcomings.
