Mississippi Hwy patrol
RMason
Mississippi / Colorado
Mississippi Highway Patrol is on the MSWIN trunked system:
You will need to program the appropriate site(s) and talkgroup(s) into the HP2.
The nearest site to Como is:
3 (3)022 (16)SardisPanola769.28125769.53125773.06875774.31875c774.56875c774.81875c
The talkgroup for Troop E is:
DEC HEX Mode Alpha TagDescriptionTag
1403136cfTeMHP D3 DISPDistrict 3 - Troop E DispatchLaw Dispatch
For programming tips, see:
Alteratively, for a quick start, you can try monitoring from the full database using the location based scanning feature of the HP2. Enter you zip code and make sure that the Law Dispatch service type is enabled.
See also: HOMEPATROL‐II OPERATIONS beginning on Page 11 of:
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
To add to the info above, mode "Te" means partial encryption meaning you'll hear some transmissions but not others
slhbeard
Vicksburg, Ms
I can't say for sure, but I think all MHP Dispatch has gone unencrypted. I know MHP Jackson D1 Dispatch is in the clear. The car to car is encrypted. Also, D2, D5, D6, D7, D6 and D9 Dispatch are all in the clear. These are the only ones i can receive. Just can't say about D3 and D4 Dispatch.
RMason
Correct. MHP dispatch channels are not currently encrypted. The database shows Te (partial encryption) instead of no encryption because they obviously have the capability, they are just not using it at this time. They were fully encrypted in the past.
slhbeard
Vicksburg, Ms
They still have SWAT, MBI, INTERDICTION, MOTORCYCLE, AND OTHER STATEWIDE CHANNELS ENCRYPTED.
