scannerowner
Why do you need tones programmed? I guess I don't know what you are trying to accomplish?
100% correct.DCS is the digital version of CTCSS/PL.
so instead af a low frequency hum it is a morse code thing going on as in ones and zeros on an analog system
NAC is what they use on a digital system
Let's say you have 2 agencies using the same frequency and each one uses a different tone and you only want to hear one and not the other.Why do you need tones programmed? I guess I don't know what you are trying to accomplish?
Leave it on CSQ and call
IS CSQ search ok? my radio shows the CSQ then i can program it.Leave it on CSQ and call it a day.
I'm sorry I meant squelch mode for Point to Point, Should it be set to CTCSS, DCS OR Search? Also should I search for Value, cause if found I can program it in my radio. Thanks sir.100% correct.
repairman222, why leave it on search ?
you radio might get it wrong as i have heard about a digital tone being decoded as an analog one.
I concur here. If you want to hear what's on Point to Point you only want carrier squelch. I can't think of any agency that used CTCSS on Pt to Pt (or 155.730 for that matter). CTCSS, etc., is to EXclude things you do NOT want to hear. Just leave it at CSQ and be done.Just leave it off. If you search then you can see what agencies are using tones, but I'd leave it off.
St Louis County PD did send a PL tone on 155.370 some time ago now. But... they only used the tone when they were sending their callsign in CW over the point to point frequency.I concur here. If you want to hear what's on Point to Point you only want carrier squelch. I can't think of any agency that used CTCSS on Pt to Pt (or 155.730 for that matter). CTCSS, etc., is to EXclude things you do NOT want to hear. Just leave it at CSQ and be done.
In Jefferson City when on analog years ago, their PD also used CTCSS to avoid having to hear their CWID, which I agree would have been both annoying and disruptive if there were something more of interest and I'm talking about the vehicle radios. Many of the reserves had their own radios in POV's, mostly Midland, and they were easy to program. Since Cole county and all others around had dedicated frequencies, they only used 155.730 with other county dispatches or car to car if another county crossed into yours. Smaller counties used Sheriff's Net as their primary dispatch. Rarely we'd have to watch the console when the dispatcher had a nature call and one of us was in the office.St Louis County PD did send a PL tone on 155.370 some time ago now. But... they only used the tone when they were sending their callsign in CW over the point to point frequency.
I honestly think they did that so users could use the tone in reverse and mute the audio when the tone was detected so everyone in range did not need to hear the CWID every 15 or 30 minutes.
I never saw the tone used during normal point to point voice traffic.
