RidingDownUnder
Hi all,
as mentioned above can you mix P25 ‘TRS’, DMR and NXDN in one favourite list.
I tried adding a P25II trunking system with the correct NAC code to a favourite list which has conventional frequencies and I couldn’t hear anything. Showing in the display was full signal strength and DAT which is correct because I have this system in its ‘own favourite list‘ and it works perfect. I think the problem is adding a P25 TRS to a favourite list which has conventional frequencies can’t be done because there is no way of adding a bandplan. I think you can add a P25 frequency but not a TRS.
I just want to add, when I do a quick search hold on that P25 TRS frequency, it pauses displays DAT and again full signal strength. It seems like the scanner 536HP is not CC searching when on the CC frequency. The scanner will receive non CC frequencies to that system just not the TRS CC. Strange.
Thank’s
Anthony.
Thank’s
Anthony.
