Stearns, Kandioyhi and Meeker are on the ARMER system. You will need to program in the towersite control channel you want for those counties depending on which ones you can get and then Talkgroups. Depending on where you live in the county will play which towers you can get, etc. Are you familiar with the ARMER system? I don't know much about that scanner tho. I do visit that area and listen to those counties when I'm down there.
Give us a little more info what your looking for and be glad to help. Most of the Talkgroups and all the towersite control channels are in the database.
I have all my tower sites programmed in(Belgrade and Paynesville in stearns co, Litchfield and Eden valley in meeker co, willmar new London and hanson silo in Kandiyohi co) along with all the talk groups associated with those co. However I am only receiving willmar site
I know there is something called a band plan, but is that carried on the control channel?
Yes I don't think it have anything to do with a band plan. What kind of antenna are you using? If your using a stock antenna that came with the scanner, that's about all you are going to get. To reach distant towers, 15 + miles typically requires an external antenna.
Where do you live? I going to agree with the others that its likely a distance/topography issue. For example Willmar and Litchfield are about 30 miles apart. Even if you're located right in the middle thats still 15 miles to each tower which is pretty far for ARMER.
