jnojr
I'm thinking I might want two... a short / "stubby" one to leave on most of the time, and a longer one I can use for longer drives. I'm having an NMO mount installed.
This is really the only good choice, as Larsen Antennas are used in public safety and will outlast your vehicle. You need to purchase an NMO mount type of your choice for the vehicle.
PulseLarsen NMO2/70SH
Short 144 / 440 MHz Dual Band Mobile Antenna - NMO Base - Requires Mount & Cablewww.hamradio.com
Second the NMO2/70 for the taller antenna.
If you're not fussy about 70cm performance, a 1/4 wave 19" whip on 2m will work on 70cm.
This is the best performing dual band amateur antenna I have found.For the longer one.
Larsen NMO2/70B Premium Larsen 2m/70cm Amateur Ham Radio Antenna Dual Band
Covering the 144/440 bands. Features 3.8 dB gain on VHF and 5.2 dB on UHF. Use with a dual band radio or two separate radios. Watts: 100, Whip Length 34 3/4".theantennafarm.com
What vehicle do you have and where do you intend to mount it?I'm thinking I might want two... a short / "stubby" one to leave on most of the time, and a longer one I can use for longer drives. I'm having an NMO mount installed.
2022 Hyundai Palisade. My intention is to go on the roof.What vehicle do you have and where do you intend to mount it?
I've been doing the same for several years as well with my 4Runner. The 1/4 whip is less obnoxious when going thru parking garages in town. I swap the 2/70 back when I'm out 4Wheeling. And, joining the consensus of opinions, the Larsen 2/70 is very well made. I've modified mine to add a spring at the base to give it a little more flex when 4Wheeling.I'd often run just a VHF 1/4 wave whip since that's what I used most of the time. On 70cm, they operate as a 3/4 wave antenna.
