Mobile Antenna for MPSCS
twintip720
MI
I have heard many different answers. I am looking for a antenna to hook up to my truck to monitor p25. Any options would be helpful. I don't want a permanant mount.
bsdam
Livingston County, Michigan
I use a Motorola HAF4017 with good performance. I've also used an Antennex ABSCANC with nice results as well. Either of these coupled with a NMO mag mount should work well.
Are you strictly going to be monitoring the MPSCS, or other bands as well?
-B
Michigan
Wait I am confused , am I missing something here. Isn't monitoring MPSCS mobile difficult or near impossible since no scanner can adequately decode P25 Simulcast? Well I mean when you are in a vehicle you will be mobile and moving around much. I know I have P25 Simulcast distortion/ phase problems while portable with my Pro-106.
rdale
Lansing, MI
Depends if you're talking about monitoring a simulcast system or not. Most of the state is not simulcast.
That's why it is better to get a good antenna if mobile.
Michigan
Well I suppose I meant Simulcast. I was under the impression that it was the radio / scanner that has the trouble with Simulcast not the antenna...
rdale
Lansing, MI
It does, but a better antenna can help quite a bit.
Michigan
Hmmm maybe I'll give it a try.... I mean it would also help if I did not live pretty much right in the middle of 2 Macomb MPSCS towers... :(
bsdam
Just MPSCS, what is a good place to order or buy them?
AES carries the Antennex here: AES Price list ABSCANC
AES carries the NMO Mag mounts here: AES Price list (Part no: GB8PSTI)
Depending on the scanner you will need an adapter to connect the antenna cable.
For a GRE or RS scanner a SO-239 to BNC Male will be needed: AES Price list (Part no: AMP 2900)
For a Home Patrol or Uniden scanner a SO-239 to SMA Male will be needed: AES Price list (Part no: HS05)
I've done a lot of business with AES and am very happy with them.
Enjoy.
-B
