Mobile antenna for VHF Lo band (31-43mhz)
Grog
Banned
West of Charlotte NC
I'm thinking of running a dedicated scanner for VHF Lo band in my truck. I've always used either a 20" whip or a mfj dual-band mag mount (I know :lol: ) for all freqs I monitor.
I'm going to do a full install (several antennas) for my car & truck (94 Caprice & 95 Bronco) which will give me several options.
I want to monitor NC Forestry @ 31mhz & the Highway Patrol @ 42mhz. My primary options are a base loaded antenna tuned in between or a shortned 102" on a ball mount? I know the ball mount is hamsexy :D and If i ever upgraded (tech always :wink: ) I could always use that mount for HF.
If you have any other sugesstions, let me know :)
INDY72
Indianapolis, IN
You could also use an NMO mounted 35-40" whip.....center rear deck mounted on da pricy'
Also depends on just what else your going to monitor... Best bet is one for each band..... Yeah youll look like a cop but oh well youll hear the action..... Say VHF Lo- 35-40" NMO left side, VHF Hi- 28-32" NMO right side.... for the caprice....
On the Ford- Roof mounted NMO's, or hood lip mounted. Last resort use the ball mounted in its side or ass,.... Or bumper mount it.
I suggest NMO mounted over ball mounts anyday as they perform much better... Larsen, Antennex..... Any good brand, but the NMO trunk/roof mount kicks the ball mounts ass. The only good ball mount would be an actual 60" VHF Ball mount off an cruiser :) Other than that ball mounts are better for CB's.
Grog
Banned
If I went for the ball, it would only be Lo band on the truck, but I figured I'd probably go the NMO route.
The problem with the caprice, is that 18 months ago, It was the chief's car in a small town where I travel. That's why I've postponed putting things on it. I'll probably get a ham tag & make sure it can't be mistaken for a current issue car. Probation & parole, Dept. of Corrections, & a few others stuill issue the 93-96 B-body chevys around here. I don't want to find all my tires flat at the mall :D
I'm going to try to limit the car to three antennas. One 5/8 2mtr (or 2mtr/440), one 800 dedicated, and a scanner antenna. I'm thinking of the antenex that's been recommened here, or stick with a 20: whip and see how that goes.
The truck will be decked out, as that's what I use for ARES/Races & general ham stuff.
KC4ZEX
Meade co Ky.
My suggestion for the low band is a Larson NMO-50. I bought one about 3 yrs ago, have it on top of a jeep cherokee use it for 6 meters. Its about 44 in tall works great. I am sure it would monitor the entire low band very well and is rugged and looks good.
