Mobile antenna Larsen 150/450/800 or Maxrad BMAX-SCAN 1000
smittyj77
Brockville
Ok, Ive got it broke down to 2 antennas now after all my research. Now id like some of your input. Im looking at the Larsen and the Maxrad I listed in the Topic. Mainly Listen to 142, 148, 154 mhz area but dont want to lose 400 and 800 mhz areas..
Just looking for input here guys. Thanks
PNW
Larsen 150/450/800 user here. Performs very well on 150/450, haven't had the chance to monitor much of the 800 MHz spectrum with it. This is presently being used as a base antenna.
I have not heard much about the Maxrad model, but they are probably pretty close in performance for monitoring.
Skypilot007
Medford, NJ
Larson 150/450/800 here too. I found to my ears it works just as good on 800 MHz as a dedicated band specific 800 MHz antenna I used to run. Now I can hear on VHF and UHF too.
KT4HX
Spotsylvania County, Va
I can't comment on the Maxrad as I've never used one, but I am a Larsen 150/400/800 user for the past four years or so. I was using a Nil Jon Super-M mobile, and decided I wanted to try the Larsen. Needless to say, I have felt no need to switch out the Larsen like I did the Nil Jon. I don't see that I will ever want to either. I use one on my truck and one in my second floor shack, magmounted to an old cookie sheet. Gives me the reception I'm looking for.
smittyj77
Brockville
Thanks everyone for the info, Larsen it is then. Now to order the antenna, nmo mount and bnc adapter.
Ill let everyone know how I make out when I get it, run now im just running my scanner through a splitter and out my radio antenna.
W4EMS
NoVA
Had both, not much difference. Both are well made.
3mary2
Las Vegas, NV
I just bought the BMAX-SCAN 1000 and have been using it for alittle over ninety days now. I get good reception on all the bands except the Nellis AFB (400's) The Larsen 150/450/800 does alot better in all the areas so I will be switching back to the Larsen. Maybe I can figure a way of using the BMAX-SCAN100 at the house.
