I have a 92 corvette convertible.
I currently run coax up through the windshield pillar, comes out the weatherstrip and then terminates into a BNC connector which is attached to an 800 MHZ ANTENNEX rubber-ducky antenna at the top most point of my windshield frame..
It actually doesnt look too bad either as the antenna extends off the windshield frame at the same angle as the windshield frame 'rake' angle (prob not best for reception, but looks good).
This works 'good' for what it is. I am not expecting stellar reception out of this low-ride height fiberglass vehicle.
However, Id like to know if there are better antenna options. Ive seen the long CB antennas that are built into a special frame behind the rear license plate. However, I dont care about lo-band CB.
Mounting something to the frame or rear deck lid - forget about it. Not worth it to me. Also, its a convertible so, I cant just put a roof antenna on w/ wires through the t-top (targa) top panel. ...
Does anyone have any recommendations on 800 MHZ (primary freq) w/ vhf (150 mhz) secondary capability antennas that do not require a 'metal' ground plane.
Well, I guess a metal ground plane would be ok if the steel windshield frame 'counts' as a ground plane. Though Im not sure it would (correct me if im wrong)
The smaller the antenna the better
