I got a new to me transceiver that I would like to install into my Jeep, but I'm not sure what antenna would best suit me! I have a mounting point for an antenna on my rear bumper as well and would like to use that location to mount it.
You really don't want the antenna mounted on the bumper. That's going to put it in a place where it's running in close proximity to the body. That's going to make it perform very poorly. You want the antenna up above the body panels. Jeeps are a challenge, but may have successfully installed amateur radio antennas on jeeps.
Seeing as the roof is fibreglass there would be no benefit to mount it on the roof..... So going back to the question, what would you pros recommend for my situation? What ones should I stay away from? BTW there is no APRS on my local repeater, if that makes a difference! Thanks for your help!
You -can- mount the antenna on the fiberglass roof, you just need to supply a ground plane under the antenna.
yes, you can do a half wave antenna, which doesn't require a ground plane, but it's going to work better with one. Plus, I haven't seen any good half wave dual band antennas that would be appropriate.
So, two options:
Use a thick mount NMO through the fiberglass. Install metal foil adhesive tape under the mount in an "X" pattern, with each of the 4 legs of the X being 20 inches long.
or, get a diplexer. That'll split the antenna output on that radio into two separate ports. One port will be for the VHF side, the other for UHF.
Then, install two NMO thick mounts through the fiberglass roof and install a 1/2 wave VHF and a 1/2 wave UHF. If you want to go a step further, add the metal ground plane under the antenna mounts and get some more gain easily.
But, if you want to mount one antenna and not on the roof, I'd second the Larsen NMO-2/70. That's one of the most respected antennas in the hobby.
