I have the regular dipole up, 1/2 wave horizontal, and it seems to get out. So far I've only talked to one person about 2 miles away and he said I sounded good. Also, he was on the end side, not the direction I'm broadcasting. My dipole is east west and he's east, so I'm somewhat encouraged.
I don't have a good SWR, it was 3:1 on ch 40, same on ch. 1, and about 2:5 on ch. 19. That was with 100' of coax. I can't go below 70', that's where it comes out of the wall. I used the full 100' because that was the length I bought and it came with connectors on both ends, so I thought I would just run it and use it.
Last night I did some calculating on signal velocity and wavelengths and came up with 15.29' as lengths I should use ( 492 x vf ÷ frequency), my nearest length over 70' was 75.95' so I cut it there (I read many posts saying length isn't important, and just as many saying it is) .SWR stayed at 3:1 on 40 but dropped to 2:1 on ch 1. I wish it would have gone the other way as everyone I know is on the higher channels. After that I read later in the same post that you should just go by 11' lengths, but it's too late as I'm already under 77'...
Reading other stuff on the web, someone put together a page on making a choke/balun by winding the coax around a piece of PVC, I'm going to try that and see if I can get the SWR down.
Optimum Coax Coiled Turns Choke Baluns for Antennas
I'm hoping that adding that balum and adding a ground at the antenna end, I can get the SWR down...
The firestick dipole:
I still haven't put this one up yet, I was waiting on one part. After reading on this post that I want the coax leaving the dipole at 90 degrees, I ordered a 90 degree connector, and it just came here yesterday, Sunday. I'm planning on going to the attic tomorrow and installing it.
I was worried about all of this being a waste of time and money, then I thought, if all this fails, an antenna tuner and small boot will fix it all, but I'd rather not have to go that route.
