CommunicationsFreak
Just making sure the company/seller doesn't sell needless stuff and $$$ are spent. Need input/suggestion on powering a vehicle that will be loaded with equipment configuration listed below used as a mobile command vehicle (full size SUV/pickup truck) besides a external/portable generator?
It needs to power at least 3 (to max output) or all in low/medium power, with some to spare for laptops, etc.
1.) HF 1.6-30 MHz* Micom/Mobat (w/WIMA HF Antenna, bumper mount) @ 125 Watts Max. (13.8V +/-20%, 29A)
2.) VHF-AM 118-136 MHz* @ 36 Watts Max. (13.8V +/-20%, 5A)
3.) VHF-FM 136-174 MHz* ** @ 110 Watts Max. (13.8V +/-20%, 20A)
4.) UHF-R1 380-470 MHz* ** @ 110 Watts Max. (13.8V +/-20%, 24A)
5.) UHF-R2 450-520 MHz* ** @ 45 Watts Max. (13.8V +/-20%, 24A)
6.) VHF-AM/FM**, UHF-1**/2**, 700**/800** or V/UHF to HF Cross link* ** any @ 5 Minim. to 110 Watts Max. (13.8V +/-20%, 24A max dependent on band)
Note: Not for all applications
7.) Emergency Beacon DF Unit (4 Roof Mount Antennas*) @ 12 VDC/Cigaret lighter powered.
8.) GPS Navigation. @ 12 VDC/Cigaret lighter powered.
9.) Portable IMPAC System 2/3/4G LTE Cellular Capable, Daniels Repeater**, or portable single radio charger/s.
Note: Not for all applications, and not roof mounted.
All antennas mounted on a roof rig.
*1, 2, 3, 4, 5 and 6 normally operated at minimum required output. Removal of other antennas (NMO mounts covered) when high/max output is need. **Analog and P25 (GPS, Encryption, etc).
Important Note: Already know that at max Tx output it can and is a RF hazard.
Any other technical info needed???
Your knowledge is greatly appreciated.
