Mobile Install Question
mgorman87
I have a PRO-163 and currently it sits on my dresser next to my bed. I want to put it in my car securely but also be able to easily remove it to take it back inside. Does anyone have any ideas or suggestions? I also was thinking about using the car antenna as the source for the scanner. They sell adapters that split the antenna cable into a BNC and radio. has anyone heard anything about this?
code3cowboy
CA-CZU
Use a bail bracket with knobs. You can use the broadcast antenna for the scanner as well, it works just fine.
mgorman87
ok im a n00b at this. what's a broadcast antenna? is that the car antenna?
wwhitby
Autauga County, Alabama
My experience with using the car antenna has been hit or miss. I had one car where using the antenna worked fine for my scanner (it did kill AM reception, though.) However, in another car it didn't work that well at all.
I would recommend an external antenna on either a mag or trunk lip mount if you didn't want to drill the hole for a hole mount.
As a mount, i'm a big fan of the PanaVise in-dash cellular mounts. I use them in both of our family cars to hold my portable scanners using the scanner's belt clip. To keep the scanner from flying off in a turn, I use a fine threaded bolt run through one of the PanaVise mount's holes. The bolt is sleeved with heat shrink tubing to keep from mucking up my scanner's case.
