Mobile Part of Radio Reference
jerry092975
Chester County, Pennsylvania
I didn't see a mobile forum so im posting this here there's a problem when you click on mobile it gives you this message UNABLE TO RETRIEVE DATABASE USER ACCESS INFO--> Table 'portal.audio_feed' doesn't exist.
RR Mobile
jdink
Fayetteville AR
I get the same msg. Im unable to download any live audio, first time using mobile access, hopefully its a temp issue, have you used mobile before.
kennyloatman
Cumberland Co., NJ
RR Mobile
Anyone else having trouble getting into RR mobile. I am getting a "unable to retrieve database user access info" message. Been like that all day.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Are you guys still getting this error message? I'm unable to reproduce.
If you are still getting this error, please walk me through the exact steps so I can reproduce and fix. Thanks!!
hvscan
Hudson Valley, NY
If you are using a Blackberry, click - browser, menu, options, cache operations, clear everything, exit. Then go back to RR from your browser and you should be all set.
**UPDATE - was only able to get a page or 2 in and problem re-appeared.**
kma371
Wirelessly posted (iPhone 3GS: Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
Working OK for me on iPhone.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
What mobile devices are you guys using who are experiencing the problem? I'm still unable to reproduce this problem.
Viper43
No problem on my Blackberry yesterday, may be a local issue or it may be a phone memory issue. I had a similar situation Sunday and was told by tech support to remove the battery with the phone on and was able to connect once it restarted.
V
jerry092975
And it still giving me and some other people this message UNABLE TO RETRIEVE DATABASE USER ACCESS INFO--> Table 'portal.audio_feed' doesn't exist... in other words it's saying the mobile feed is not there because it's saying Table 'portal.audio_feed' doesn't exist
jasonk
Dayton, OH
MOBILE Problems
The Mobile Site has definitely having some issues. I usually connect to it from my PC every morning .....Now I get this error.
"UNABLE TO RETRIEVE DATABASE USER ACCESS INFO--> Table 'portal.audio_feed' doesn't exist"
It may be specific to My Login - but I sense it is a bigger problem. If I bypass the Start Page - and use a Direct Mobile URL - I can open the site fine.
RR Mobile - This will not work ....
Admins may want to check it out ....
Jason Kinley
jasonk
Dayton, OH
From PC
I get this message from my PC - Used to log in every morning. Started this Monday ....
Jason Kinley
