Mobile setup for Car
Seanm214
Kings Park, NY
Hello, hope I am posting this in the right thread but I am still new to ham radio and want to get a Mobile rig to put in my car. Thinking about getting the TYT md9600. The only problem is that I have no experience on how to install one in the car and how to hook it up to the battery and all of that fun stuff. Does anyone know of any good resources that would give me specific step by step instructions on how to install a rig in my car. Trying to learn as much as I can and the right way to learn so it will be easy in the future. Tried looking on YouTube but the videos are not really step by step and not easy for a beginner like me to comprehend. Any information would help.
Thanks,
Sean
AI7PM
The Intermountain West
Welcome to the hobby.
www.k0bg.com offers some good insights. I've lost track of how many installs I've done over time, but it includes everything from car stereo to patrol car radios and equipment. The first piece of advice I'll offer is, disregard any instructions in a ham radio manual to connect the negative directly to the battery, or fuse the negative. Ground to the vehicle chassis as near to the radio as available and without a fuse. In addition, use a good quality wire for the positive with a jacket suitable for under the hood environments, and fuse it within 5 or 6 inches of the battery. That generally is not the wire quality provided with the ham radio.
The second, actually install (not clip, mag mount, slip on trunk mount, thru-glass, etc) an antenna rigidly to the vehicle. NMO mount into the body, or at least, a quality "L" bracket secured with screws in a hood or trunk body gap. Mount a quality antenna to it. Laird, (Laird 2/70 very popular and good) Atennex/PCTel, Comtelco, E M Wave, or alike. Using a cheap antenna on your radio is like using cheap speakers on a good stereo. Disregard DBi gain figures, they are marketing crap usually found on makers of lesser quality antennas. More gain on an antenna isn't necessarily a good thing, or a measure of the overall antenna performance and quality.
AI7PM
BTW, a local two way radio shop will generally install an antenna for you at a reasonable price. Many hams take that route until they have been exposed to the process over time. They might even let you watch.
krokus
Southeastern Michigan
Wiring the positive lead directly to the battery, paying to routing, lowers chances of noise being induced. This can drain the battery, so keep that in mind. You can wire a relay into the lead, controlled by switched 12V (AKA accessory power).
AI7PM gave some good advice.
Be wary of YouTube and "Amateur Radio Expert" installs. A lot of the information out there is not only wrong, some of it is dangerous.
The radio is a heavy chunk of metal mounted inside the passenger compartment. It needs to be secured well. Velcro, double sided tape, small sheet metal screws, bungi-cords, etc. are NOT appropriate installation methods. Your first step should be finding a way to properly install the radio chassis. It needs to be well secured. You need to mount it in a place where it will not block your vision, will not be in the way of airbag deployment, is not exposed to direct sunlight, and you can still reach it easily. That will entirely depend on your vehicle.
I've always through-bolted mine, that is I locate the mounting bracket, drill through the underside of the dash or other location, and fabricate a backing plate that has holes that match up with the bracket. The backing plate gets put on the other side of the mounting location, and usually 1/4" x 20 screws with locknuts, washers, etc. get passed through the bracket, dash and backer plate. This will keep the radio secure on bumpy roads and prevents it from coming loose in an accident.
Your antenna is the most important part of the install. If you are not willing to properly install an antenna, you should probably reconsider installing a radio. Compromise mounts and cheap antennas will lead to compromised performance. Don't spend $300 on a radio and then hook it up to a $20 antenna and expect it to work like a $300 radio.
Permanent mount NMO dead center in the vehicle roof is best. Anything else is a compromise. Yeah, there's other options, but they have drawbacks. Use a name brand antenna. Avoid amateur/hobby grade antennas. Avoid the low cost Cheap Chinese Antennas.
Power is important, too. Do not cut corners on your power feed. Do not tap into existing vehicle wiring, that's asking for lots of issues, not the least which is RF interference. The positive power needs to come direct from the battery. Negative needs to be grounded to the body near the radio. I've often added a chassis ground strap from the radio chassis to the vehicle sheet metal. Relying on long negative power leads or ground through the antenna mounts can be problematic in some installs.
It's a big step, and not easy. As you've discovered there is some totally useless info out there on the internet. Some of the "internet expert" installs I've see are truly horrifying. On the other hand, it's not really that hard to do yourself if you've got some basic skills. There are some vehicle dependent things you'll need to sort out, but we're happy to help.
