Modified etrunker version
I have attached for anyone that may want it ... a copy of a new etrunker. It has one feature that in my opinion makes etrunker a little bit better.
I have added a system time .. and it will autosave at the top of the hour. This is a little bit safer should something happen while the pc is running ..
This is a beta version but I have been running it for some time with no problems.
If there are any concerns let me know and I will change it ..
To install .. just unzip. I recommend renaming (just in case you dont like this one) your existing .exe and put this one in its place. Other than the changes above this should be identical.
Enjoy .. 8)
crayon
RF Cartography Ninja
36°33'01.2"N 98°56'40.1"W
I have been running this copy of etrunker without any problems since November 7th. The autosave is a cool feature.
wow. Seem like it has be longer .. :)
Yes .. you are the only one other than some of my friends that have this version up until now as you had asked for it. Who knows if people have other ideas to make etrunker better .. maybe they can happen as well. Its mostly having the time to do some coding.
Hope you enjoy .. :)
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
yes, I'd recommend you build ESK support into this version, as well as reference a single IDS and GRP file for every site versues different ones. ESK support could be as simple as a ESK=0 / ESK=1 in the ENV file.
This is what I compiled into my version of Etrunker, however I never released the GRP / IDS updates...
I just changed the code to reference ids.txt and grp.txt versues xxxxids.txt and xxxxgrp.txt.
Makes managing files for wide-area systems much easier.
-Lb
Lindsay ..
If you send me your source .. I will recompile it and replace the .zip above.
Kevin
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
edmscan said:
Lindsay ..
Kevin
Sweetage... I'll dig it up after the T-giving holiday's and send it to you.
-Lb
