FireDawgEMT22
- Joined
- Jun 15, 2006
- Messages
- 136
Ok, I started a discussion in another thread earlier, and it changed over to more of an antenna feed line issues questions, so I decided this is the proper forum to bring more light on it with.
I have a PSR 600 monitoring VHF, UHF, and 800Mhz. The antenna I have is a RS 20-176 about 35-45feet up. I HAD 25 feet of RG58 running to a splitter and then from the splitter 60 ft of RG6 to the back of my scanner. I had the splitter in to attach my minitor V charging base that I added an antenna to, but I think I am just going to make a simple Dipole antenna for that.
So I removed the splitter and the RG58 and just have the 60ft of RG6. I can pick up the VHF signals MUCH better, even had to turn on the attenuator to get the signals clearly. But I am still having problems picking up the 700MHz trunked system that is broadcast from a single sight 33 air miles flat terrain away. I actually cannot get the signal to even break the squelch on tune mode.
I modified the antenna by adding two 3.5" rods into the antenna 90 degrees out from the UHF elements and it still did not help. Is there another modification I can make to this antenna or some other change to help with this reception.
I have heard alot about the Antennacraft Scantenna ST2. I have heard they are junk and stay away from them, and heard they are the best thing since sliced bread for receiving. If I am doing NO transmitting, would getting this antenna be the miracle I have heard it is?
Thanks in advance for any tips and advice you guys can give me.
