Modifying Pro-96 "V" Folders
wirelesscop
Hey Everyone,
Can someone please tell me IF it's possible to modify the V folders in the Pro-96? I can see in the WIN96 program in the "Scanner" area up top that you can access "Virtual Scanner," but I am unsure what to do from there.
What I really want to do is be able to edit / modify the V folders so I can just load the different information from within the scanner depending on where I am and what I want to listen to instead of having to hook the unit to the computer to do it.
Make any sense?
Any help is much appreciated.
Thanks in advance!
jeffrey420
You can load the info into the working memory and the transfer it to one of the v scanner banks. You will loose the default data in that v bank.
Page 77 of the manual explains this procedure.
TES
America's High Plains
wirelesscop said:
Hey Everyone,
What I really want to do is be able to edit / modify the V folders...
Run Win96 and read topic *Virtual Scanner Interface* found in Win96 Help.
jeffrey420
I would like to, but have never been able to get the help file to work.
