Modulation on P25
bkramm
Benton County, IA
I managed to get the modulation on some P25 frequencies ? changed to FM from NFM.
I found how I did it on the scanner, but is there a way in Sentinel to get these changed back?
Guessing it changes the freq to FM not the TG?
I tried reloading the favorites list with the erase favorites on scanner checked but didn't seem to help.
Any other guesses besides doing it manually on the scanner.
Is there anyway to change the modulation on P25 in Sentinel?
thanks
hiegtx
Dallas, TX
thanks
For conventional frequencies, the modulation setting is on the same line with the frequency & text tag. You can see that through the Favorites list editor in Sentinel.
79007
For older, analog, trunked systems, you can change the setting on the Options tab via the Favorites list editor in Sentinel.
79008
For P25 trunked systems, you cannot update their modulation in Sentinel, or on the scanner itself.
For for DMR or NXDN trunked systems, modulation can be set using the Options tab when editing the site (the same way as noted for analog trunked systems).
You can set the default modulation, as well as step size, for a given range of frequencies under the Band Defaults tap in the Profile editor.
79010
bkramm
Benton County, IA
Thanks hiegtx.
I had already just found that one of the band defaults was changed to FM from NFM. ( Probably me )
That is probably why the reload of the favorites list did not correct the problem originally.
On a P25 system I can hit channel (to hold) then hit function then the MOD button and change
the modulation on I think the P25 freq. It will step NFM, FM and AUTO with each push of MOD.
I have already set many conventional freq's to FM from auto or NFM.
