MOL cps bluetooth conection question?
K
kk4mei
Guest
I can get my radio to pair and connect to my computer as a serial port connection on com port9 is this correct to work with mol cps or do I need to make a network connection?
wsykes41770
Rochester, NY
You can't program the radio via bluetooth. The bluetooth option that is available on Motorola radios is only for two-way audio, similar to a bluetooth headset for your cell phone. To program the radio you will need the correct programming cable.
K
kk4mei
Guest
http://www.va3xpr.net/motorola-mototrbo-xpr7550-portable-radio-review/
it does program via bluetooth found out the CPS uses a ip address to connect soo it needs the pair and connect as a personel network.
https://www.youtube.com/watch?v=qxeTemBH-M0&feature=youtube_gdata_player
com501
Of course, if you have ANY glitches in the connection, you now have an expensive bluetooth enabled BRICK. Best to program ANY radio with a physical connection.
wsykes41770
Rochester, NY
I stand corrected. The Public Safety radios I deal with don't have that feature, probably for the same reason as com501 stated. I would still use a cable to program it with, but that is my preference.
