Monitor Mode Lockout
JASII
Memory Capacity
Unication David,
I gather from other posts here that there a lots of other priorities, but I am just wondering if the ability to lockout talkgroups/channels while using the Monitor Mode might be a possibility in the future?
The other thing that I would love to see is the ability to mute the audio on encrypted talkgroups. Could that ever be a possibility in the future?
Thank you in advance!
Jim
David_Oney
Former Unication Tech Support
Unication Representative
Raceland, KY
Unication David,
Jim
Both are possibilities but haven't been implemented yet both of these features are on my list of desired features so ill keep you posted.
sfd119
Any word on this? Both suggestions would be very useful to me as well.
Fire125
FF/EMT/HMRT
SE Michigan
monitor mode G5
hi, could someone please explain the monitor mode under function status on unication G5 ?
cpetraglia
Fairfax, VA
Very simple. Once enabled, it will hit on every and any TG that is active on a given system. That's all it does. You have to enable or disable it per system. There is no setting for it in PPS, only thru the menu.
Fire125
FF/EMT/HMRT
SE Michigan
Does it scan whole the system with or without comtrol channels? What i mean is doescontrol channel have any affects on it?
And thank you for responding back!
hiddenrun
Commonwealth of Pa
The monitor mode will monitor ALL talkgroups on a system. You will still need to program your Control Channels and your system information.
So switching monitor mode on will monitor the whole system regardless of the talkgroups you have programmed on that system.
Hope this makes sense.
mpreece
Wyoming
Monitor Mode Issue
On the VHF P25T system I monitor, when I use Monitor Mode, after each transmission the G5 drops the signal and takes 5-10 seconds to reacquire it. This happens even when I have set a site-specific knob position. I contacted my dealer (Ray) and he mentioned this has happened to others. I sent a note to Unication but haven't heard if this is a known issue. All other functions seem fine. This is on the Wyoming WYOLINK system so I wonder if it is a system-related issue or some obscure setting somewhere.
