I've started to dabble in monitoring a local Connect Plus trunking system (FleetConnect 158 in Southern Ontario) with DSD+
The site I am monitoring, Site 16, has 4 identified frequencies according to RR database.
https://www.radioreference.com/apps/db/?sid=7079
Slicerwizard stated in another post of mine that
Per the docs, DMR channel numbers should be odd (1, 3, 5), not 1, 2, 3.[/code] With that, I'm not sure how to interpret the database. Are the small grey numbers preceding the frequencies the channel numbers? If so, there are even number channels?
Regardless, I entered the four frequencies into my DSDfrequencies file. I did subsitute the even numbers with odd and came up with this ...
This results in the DSD+ CC Channel Activity Window displaying...Code:Con+, 158, 16, 01, 451.5750, 451.5750, 0 Con+, 158, 16, 03, 452.0375, 452.0375, 0 Con+, 158, 16, 05, 452.6625, 452.6625, 0 Con+, 158, 16, 07, 452.9375, 452.9375, 0
Ch 01 451.5750 50 CC
Ch 02 451.5750
Ch 05 452.6625
Ch 06 452.6625
The frequencies are duplicated. Is this correct? Also noticing that when there is voice being transmitted on "CH2" that there is an echo. Is this normal? Is it a symptom of something being off?
I'm noticing the voice to be very poor. Legible but very garbled. Is there a setting that can clean that up any?
