Monitoring Butler County P25
KD8MLK
Cincinnati
Hello! I'm considering buying a Pro-96, with the hopes of monitoring BRICS (and perhaps hamilton county as well). I heard that they are going to switch the system to TDMA (phase II, I'm assuming), which would make it unheard on the Pro-96. Is this true?
Also, how much of a problem is multipath? I'm located in fairfield, I don't want to end up getting a scanner and not even be able to listen to it.
Thanks!
-Andrew
radioscan
Radio Sensei
Butler County, Ohio
Please cite your specific sources for this. I know several people involved with the system and this has never been brought up.
Some people have reported a problem with this. It all depends on your location between tower sites. The newer generation scanners such as the PSR-500/600 will provide much better audio and digital decoding than the Pro-96 will. Some remedies are to use the attenuator or use a yagi pointed at the closest tower site to help reduce multipath distortion.
KD8MLK
Cincinnati
Thank you for your response! The phase II thing I read was from another member, however I might have misunderstood him.
I would like the Pro-106, but I'd like to use a 96 if at all possible (only reason being the price). I read you mention that the fairfield site is in harbin park. I am within a literal line of sight range of it (I can see the site from my window). Do you know where the other sites are? Hopefully if they are far away enough I wont have the problem.
Thanks again
swstow
Erlanger Ky
i have the butler system in my 96 and it works great / sometimes better then hamilton
RadioDaze
Orange County, California, USA
KD8MLK (Andrew) is considering the purchase of my Pro-96. If someone could send me a Win96 ".p96" file that includes Butler, and perhaps Hamilton, I could load it into the scanner to get him started. Presumably, the file would include any custom rebanding tables.
Otherwise Andrew will have to tough it out himself ;)
