Monitoring Christiana Care
KB3PTP
Wilmington, DE
So, is Christiana Care on an LTR analog trunking system, or do they utilize conventional DMR channels?
With the Covid-19, I thought it would interesting listening. I programmed the system as an LTR analog trunking system and not hearing anything.
Does anyone know? Also, if its not an LTR analog trunking system, why does the database reflect this and why hasn't it been updated? Thanks in advance.
u2brent
OAMPT
KRWDPAXKRS1
The License also authorizes DMR emissions.
The DB for that LTR hasn't been updated since 2012, It likely changed to DMR.
82330
The RR DB is only as good it's members submissions..
It could be conventional but more likely a trunked DMR system possibly Cap+.
Only way to know for sure is to do an investigation.. :)
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Christiana Care is entirely encrypted, DMR Cap+. I can at least speak for the Chadds Ford, PA site (Site 3) being CC-11
463.875 ch 1& 2 (LCN 1)
464.9625 ch 3 &4 (LCN 2)
TGs I observed (all encypted):
10: Most active, 19, 30, 40 & 41. Common RID across all TGs seems to be 65533 (dispatch perhaps?)
tvengr
Well Known Member
Baltimore County, MD
This is probably outdated, but did you try these?
451.40000 WQEJ558 BM754 DPLCCare MaintChristiana Care Health System maintenance FM Hospital
451.60000 WPQA234 RM315 DPLCMH- SecuritChristiana Hospital - Security FM Security
philacop
Clifton Hgts PA
Site 1 CC 11
463.6125 1-2
464.0500 3-4
464.8375 data?
Site 2 CC 11
451.7500 1-2
451.850 3-4
452.225 data??
Too far to catch an Site 4
All Enc
Security TG may be 10
Whiskey3JMC
DXpeditioner
Continued from above since my 30 minute edit timer ran out: If I were to venture a guess I'd say TGs 10, 30, 40, maybe 50? could be security at different locations? All observed from Site 3, Chadds Ford (DSD+ reports neighbors as 2 & 4)
TG-10: Most active, RID=1xx
19, RID=320's to 350's
30, RID=3XX
40, RID=4XX
41 RID=470's to 500's
50, RID=270's to 290's
u2brent
OAMPT
KRWDPAXKRS1
Site Locations
1 Wilmington KXD713 CC11
463.6125 LCN 1
464.0500 LCN 2
2 Newark WQDJ379 CC11
451.7500 LCN 1
451.8500 LCN 2
3 Chadds Ford KXD713 CC11
463.8750 LCN 1
464.9625 LCN 2
4 Middletown KXD713 CC11?
452.9750 LCN 1?
464.9375 LCN 2?
  • Chiristiana Health Care Cap.zip
Whiskey3JMC
DXpeditioner
Looking through my logs, found some more:
TG-11: only RID i logged was 179, perhaps a security secondary to 10?
TG-31 only RID i logged was 308. 308 also is logged on TG-30 so perhaps 30 is a security primary and 31 a security secondary?
Whiskey3JMC
DXpeditioner
I'll probably be adding to this spreadsheet if I discover more TG's or more activity on less busy ones but I basically broke it down with each TG having its own tab (on the very bottom) in the speadsheet to make viewing RIDs a bit easier. TGs with only one hit may have been miss-IDed by my DSD+, not sure. I can pick it up from home about 30 miles NE from Site 3. So far the hits I have on the spreadsheet are about a year old
