SDRTrunk monitoring few systems with one receiver ?
ronenp
Hi there
Is it possible to monitor few systems (say one p25 and one DMR ) that are not on same frequency with one Receicer ?
if yes how can it be done
also is beta4 support DMR connect plus or capacity plus ? or not yet ?
Thanks Forward
R
lwvmobile
DSD-FME
What kind of receiver do you have?
You may be able to tune all of it if your dongle supports the amount of bandwidth you would need to spread across all of those control and voice channels. i.e., if its all contained within 2Mhz or 10Mhz depending on your device.
According to SDR Trunk, it supports Connect Plus and TIII, but you have to manually enter the LSN channels or import it from the database.
Per the man himself,
But it might seem that Connect Plus might be broken in the current Alpha 4 build per this post
ronenp
Thank U for explain
What about Capacity Plus support ?
So I understand from what you write that in order to listen to 2 systems on different bands one every band need a separate receiver
