Is it possible to monitor multiple P25 systems with DSD FL?
Yes, you dont even have to do that.By open windows, do you mean having multiple instances of DSD? Like make different folders with copies of the DSD files?
Nope, just one for CC & VC. I do the same thing - running FMP24-CC.bat & 1R.bat/CC.bat do the same thingAre you using separate dongles for CC & VC? So for each site, you would need 2 dongles? Currently, I am using 1 dongle and after FMP24-CC fires up, I use the 1R.bat to decode.
Also, if you have multiple systems running that way, would you get simultaneous transmissions some times?
Why would you keep editing files? Why wouldn't you just make new ones for the extra dongles?Yes, you dont even have to do that.
Just open your FMP24-CC.bat & CC.bat, then after its running, go to that same FMP24-CC.bat file and click edit, change the RTL device # (-i#), and then open it again.
You dont need to make additional folders.
For example, one of my SDRs is listed as device #4, and the other is #1, so by default, #1 opens when I first start, then I edit the .bat file and change -i1 to -i4, and it then opens with the other device.
It doesnt really matter - do it however youd like. I prefer doing it that way because I switch dongles in and out a lot so I dont know what their numbers are, and its easier just to open notepad and switch a single characterWhy would you keep editing files? Why wouldn't you just make new ones for the extra dongles?
This sounds like extra work because you don't have them marked & serialized, make life easier on your self?!you said:I prefer doing it that way because I switch dongles in and out a lot so I dont know what their numbers are, and its easier just to open notepad and switch a single character
Not to my knowledgeIs there no way to scan multiple CC’s with one dongle?
This sounds like extra work because you don't have them marked & serialized, make life easier on your self?!![]()
To be honest, I never put much thought into it. Ill look into thatYou can assign a serial string to each dongle and physically label them with the same identifier. Then there's no ambiguity when you plug in a dongle.
