Monitoring Room 2012
Turbo68
East Devonport,Tasmania,Australia
Hi everybody this is my monitoring room 2012 looks like what u cannot see is another Alinco DX-R8 hf receiver still in box,Icom-R8500 getting service lights on signal meter gone thanks for looking..
Regards Lino..
RADIOS:
ALINCO DJ-X11,ALINCO DJ-X2000,ALINCO DX-R8 (2)
AOR-8200MK3
FUNCUBE DONGLE PRO
GRE-PSR400,GRE-PSR500
GRUNDIG SATELLIT-750
ICOM-PCR1000,ICOMPCR1500,ICOM-R3,ICOM-R20,ICOM-R71A,ICOM-R75 (2),ICOM-R2500,
ICOM-R7100,ICOM-R8500,ICOM-RX7
PALSTAR-R30A
REALISTIC-PRO2035
RFSPACE SDR-IQ (2)
TEN TEC-320D
UNIDEN-245,UNIDEN-396,UNIDEN-780
YAESU-VR500
ANTENNAS:
ICOM-SA7000 WIDEBAND 30KHZ-2000MHZ,CENTREFIRE MULTIBAND DIPOLE 25MHZ-500MHZ,
ICOM-AH7000 DISCONE 25MHZ-1300MHZ,POLAR-214A DIPOLE 118NHZ-136MHZ,RADAR RAMA-1090MHZ,RFI-GP3 GROUNDPLANE 118MHZ-136MHZ,SCANNMASTER WIDEBAND 500KHZ-1500MHZ,
WELLBROOK-ALA1530 ACTIVE LOOP 50KHZ-30MHZ,WELLBROOK-ALA1530AL-1 50KHZ-30MHZ,
WELLBROOK-ALA1530L 20KHZ-30MHZ,WELLBROOK-ALA330S 150KHZ-30MHZ
ACCESSORIES:TOO MANT TO MENTION
SOFTWARE:TOO MANY TO MENTION
Rt169Radio
CT
Very nice!
I have a question,is it just me or are the shelves kind of bent?
KC1UA
Scan New England Janitor/Maintenance
Looks great. I'd love to hear more about the operation of the SBS-3 if/when you get a chance, unless there's a thread already going for it and I missed it. Thanks.
Turbo68
Hi only had the kinetic SBS-3 for a few weeks very happy with its performance just installed the Radar Rama-1090mhz antenna 10 metres high will connect the bnc end connector this week,the receiver on it is as good as others..
Regards Lino..
commscanaus
Melbourne VK
Awesome setup there Lino!
Which radio do you use the NIR-10 filter with?
I've been on the lookout for one of those, but they rarely come up for sale.
I know you like the Wellbrook loop antennas.
This is an antenna that I may have to consider purchasing due to the awful S9 noise floor that I now have to live with on HF.
Regards, Commscanaus.
KC1UA
I don't want to take this thread off topic, but I'd be interested to hear what you're using for software with the SBS-3, how the dual wideband receivers work, etc. If you have time to PM some info at your convenience I'd be indebted. Thanks.
Regards Lino..
Turbo68
Hi actually got 2 of the JPS NIR-10 only use one of them on the Icom-R71A only have 2 up at the monent Wellbrool-ALA1530,ALA1530L others ALA1530AL-1,ALA330S are in the bedroom planning on putting up another soon..
Regards Lino..
Turbo68
Radar Rama-1090MHZ ADSB antenna is 10 metres high with room to go kigher connected to my Kinetic SBS-3 virtual radar aircraft on screen is 224 nautical miles away aircraft dissapear from screen around the 260 nautical miles very happy with the results..
RegardsLino..
michaelmikesj
Athol, Idaho
Very nice indeed. But I have to ask. Why does someone really need this many radios. I have 2 scanners and at times it can be a bit to much to keep up with. Just wondering if it's job related or a macho thing.
Turbo68
Hi some of the radios got frequencies programmed in them and some dont my main intrest is monitoring hf aero,vhf airbands also share a radio room at dads place with 45 other receivers..
Regards Lino..
jaskel
SYDNEY AUSTRALIA
hey man how have you got that radar rama mounted? what is that arm with a 90 deg bend?? I will need to do the same set up as I will be coming off the side of the pole that has my discone at the top so i want to get it away from the pole.
I look forward to your reply champ!
Turbo68
Hi Jaskel thats called Horizontal Stand-off 1.0metrex25mm fits masting up to 56mm code HSB90 u can also get the shorter version 450mmx25mm fits masting up to 56mm code HSB45 from Laceys TV in Sydney 9755-5026 or Coffs Harbour 6651-6100..
Regards Lino..
