Monitoring SDG&E
Alain
San Diego, California
Favorites List.PNGI'm having difficulty with getting the 451 Mhz, P25 and Motorola systems to play nice in my favorites list. With the 451 Mhz and the Motorola systems, I can hear comms fine, but when I append the NextGen system to my favorites list, I get EMT & SDSO and TG's unrelated to the SDGE system...occasionally, I'll get two TGID's while ID searching is engaged. See enclosed snip.
What have I done wrong?
K6CDO
Hanover Co. VA
I suspect you will need to remove the old system to avoid duplicate appearances.
But I've been wrong before ...
Alain
Thanks Don, but each time I upload from Sentinel, I always check the box, "erase favorites list on scanner". Does that not remove [accomplish] what you are suggesting I do?
K6CDO
Hanover Co. VA
I don't use Sentinel, so I can't answer that.
Anderegg
Enter text in this field
San Diego
You need to duplicate that favorites list, then using the delete function, make one nextgen only, the the other everything but nextgen, and assign them different fav list QK's. That should at least cut down on the ways things can get messed up in Sentinel programming.
Paul
