Monitoring STARS using BCD436HP
K9DUO
Norfolk, Va
Just curious for those that have the BCD436HP, if you monitor STARS with it, how well does it follow the system being a multi site system. I know the SDS100/200 follow it flawlessly but curious about the 436HP.
jkahn
Very good looking Member
Silver Spring MD
I turn off sites that are out of my area, which speeds up scan speed. I also "avoid" T/gs I am not interested in. Works fine where ever I go (turning sites on before traveling out of my area (Silver Spring). I can monitor the Chesapeake Bay bridge and Baltimore tunnels sometimes, from home on stock antenna.
TJX400
Before I got my SDS, I programmed all control channels for STARS into one "system" on my 996P2... This way, I could have the STARS system set to a single quick key, and the scanner would automatically choose the strongest CC by itself. Worked like a charm. You should have no issue decoding and tracking it.
